MrWizard
Jan 23, 2019Moderator
you can try that
the 12v does not produce enough heat to keep the fridge cold over a 24hr period
it has never been more than a 'keep the food from spoiling mode' intended only for use when driving between campsites
130watts is not enough, the fridge needs that 350watts to operate correctly
this is my 4th RV with an LP fridge,
i had one, my very first class A, that had the 12v option, did not use it
I never use 120v electric on an LP fridge, unless i run out of propane
then i will run the genny or the inverter, and make a trip to fill the propane tank
Having RV issues? Connect with others who have been in your shoes.24,401 PostsLatest Activity: Aug 06, 2017
