BFL13
Jan 25, 2019Explorer II
MrWizard wrote:
unless you need a new control board
at least it keeps you busy and out from being in DWs way
The control board seems to work properly on gas. I did have to replace the DC fuse on it when I fumbled something the other day.
If I get the converter to supply the board, I will have to parallel it with the regular connections from that 12v connections thing where there is some voltage drop. That way I can still run the fridge on gas when not doing any converter 12v mode. Voltage drop is not a problem in gas mode.
If I ever get this 12v mode working right, I may never use it, but at least I will have the option.
Ha--the secret is to have vital work to do in the RV so you can't get to the honey-do work just at the moment :)
EDIT-- no 120v mode means you can't run the fridge off inverter and make it up with solar to save propane. If I get this 12v mode working via second converter, I could run that converter (since not connected to house batts) on inverter and make up with solar as an option in some scenarios.
Having RV issues? Connect with others who have been in your shoes.24,401 PostsLatest Activity: Aug 06, 2017
