CapnCampn
Jan 26, 2019Explorer III
Would it be worth it to use a relay to switch power to the element? Use the power from the board to turn the relay on utilizing the thermostat controls, then use the relay to run power direct from the converter to the element. Seem like that would bypass the voltage drop in the board, and get you the higher voltage (whatever you dial in) to the element.
CC
CC
Having RV issues? Connect with others who have been in your shoes.24,401 PostsLatest Activity: Aug 06, 2017
