pcm1959
Aug 08, 2014Explorer II
Thanks to all who have replied and so quickly! The switch I purchased is rated at 30amps. I could switch the plug back and forth but I'm really trying not to have to do that. I'd like a seamless (at least at the expense of flipping a switch) way of choosing between shore or inverter power. I have thought about letting the fridge run off the inverter all the time. However, I figured it to be unnecessary wear and tear on the inverter - especially in very hot weather.
I did purchase a Pure Sine Wave inverter. However, it does not have a 110 input - only GFCI outlet only.
Also, I have installed a remote switch to power the inverter on and off from inside and near the 110 selector switch that I'm tiring to wire. As a precaution, I do not plan to use the 110 selector switch to switch back and forth while hooked-up to shore power.
Thanks for all the input and so quickly! Much appreciated and I will sleep better feeling there is hope to wrap this up tomorrow. Thanks! Phillip
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 09, 2026
