pcm1959
Aug 09, 2014Explorer II
I appreciate everyone's contributions to this thread. Prior research told me that the Leviton DPDT center off switch would work and be safe to use. Hind site is always 20/20. That being said, I guess there are other ways to achieve my goal such as buying a different inverter and other types of switches and wiring.
I don't have a genset, don't dry camp, and I'm only interested in using the inverter to power the refrigerator. I felt that wring the way in which I've described would be a simple solution. The I didn't want to "power" the entire coach with the 1000 watt inverter and did not want to get into the main shore power supply, etc., etc.
My inverter is installed and connected and power to the dedicated inverter line test good. So now I have to complete the wiring between the two hot lines (dedicated inverter line and factory 110 line that previous powered the fridge on a/c), the DPDT switch, and the 110 outlet.
Thanks again for all the help from everyone and if anyone has anything to offer in regard to this wiring/switching application, please post. Thanks! Phillip
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 09, 2026
