pcm1959
Aug 09, 2014Explorer II
westend wrote:
This 15 amp Xantrex transfer switch would be perfect for your application.
My inverter does not have an a/c input - only output. I only want the inverter for the refrig and not the rest of the coach. Wring this transfer switch looks to be a bigger nightmare than what I'm trying to do. I already have an inverter installed, a dedicated line from the inverter and existing 110 power. All I want to do is manually switch between the two. If I can't figure it out I'm just going to have 2 outlets - one for the inverter and the existing 110 and simply move the plug from one to the other. Phillip
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 04, 2026
