evy
Apr 13, 2016Explorer
So if I understand, according to this article, when the circuit is under 10amps I don't need a relay? can anyone confirm?
http://www.fourthgen.net/automotive-relays-functions-uses.shtml
Is that what you mean when you say "low amp" Kayteg1?
Kayteg1 wrote:
So those are off-road lights.
25 or more amps going via add-on switch brings several concerns.
The proper way would be use relays and short wires straight from fuse box to the lights and use the panel for low amp controls only.
Having RV issues? Connect with others who have been in your shoes.24,383 PostsLatest Activity: Apr 24, 2026
