pianotuna wrote:
I started a thread that has a link to a quite conservative LI fact/suggestion sheet. They recommend, that for best battery life, 0.2 C is the maximum load (and charge rate).
0.2 x 600 amps = 120 amps. That's not going to run the microwave (or the roof air, either).
If you believe that a 600ah lfp bank can't run microwave or a/c for an extended period of time or other high draw and still get long life from them that's delusional.
From your link in other thread...
"LFP batteries can also last a very long time. Our Battle Born LFP batteries are rated at 3000 cycles, at a full 100% charge/discharge cycle. If you did that every day it makes for over 8 years of cycling! They last even longer when used in less-than-100% cycles, in fact for simplicity you can use a linear relationship: 50% discharge cycles means twice the cycles, 33% discharge cycles and you can reasonably expect three times the cycles."
They were talking about BB batteries and BB claims up to 1C charge/ discharge for 100ah battery.
