What would be amazing life if this isn't already with the capability of running higher draw items with very little voltage sag throughout the entire SOC of the battery ?
"LFP batteries can also last a very long time. Our Battle Born LFP batteries are rated at 3000 cycles, at a full 100% charge/discharge cycle. If you did that every day it makes for over 8 years of cycling! They last even longer when used in less-than-100% cycles, in fact for simplicity you can use a linear relationship: 50% discharge cycles means twice the cycles, 33% discharge cycles and you can reasonably expect three times the cycles."
