BFL13 wrote:
No idea what the Trimetric should be programmed at for charging efficiency with Li. About that, where with Wets the efficiency goes off the rails above 80% SOC due to gassing, Li being kept under 80% (however measured) and being Li must make it very high.
OP has Victron instead of Trimetric. PT said Victron accounts for Peukert while Trimetric does not (Tri's manual has a note on why it doesn't bother with that)
So Li and Peukert? Any conflict with Victron's setting?
I spoke to Victron tech and was told their battery SOC meter IS compatible with Li via a simple setting on the app...Xantrex tech says LinkLite is compatible too with Li.
