Interesting. I have the 2010 version of the Trimetric manual. I have not read the newer version(s) to see what's changed, but will later. I know Bogart has a newer version of the 2025 firmware than mine has, where they made some improvements.
It seems that if Li is usually operated under 80% if I got that right, and would have a very high charging efficiency, that the Trimetric's idea of "full" wouldn't be much use, so I was curious.
If you have a % SOC meter of some sort right on the Li bank, I suppose you don't even need the Trimetric, I don't know.
Guys with Li can figure it all out as another adjustment they have to make in how to do things!
