NMDriver
Oct 18, 2017Explorer
If you have 65 plus inches from hub center to hub center you should be fine leaving your axles where they are. 8 inches between tires seems like a lot but if that is your measurement then going up to 16 inch should not be an issue.
Not sure why you want to go up but if your 5er is less than 8500lbs loaded then you can get 15inch LT tires that will handle your load without going up in size. They are less prone to blowouts whereas a ST tire even in 16 inch load range E is still not very good at dissipating heat.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
