BFL13
Oct 18, 2017Explorer II
Wheel well clearance above the tire stopped us from going to 16 from 15. Also width issue on one side where a fatter tire would have rubbed on the metal LP gas pipe going past between tire and frame.
If you can't fit the 16s and it is to gain height for being nose high when hitched, be sure you look at raising the pin box (ours had three height options) and lowering the hitch---juggling all the while how much clearance you still have above the truck box rails.
If none of that gets it done, then you are left with putting spacers between frame and springs to gain height back there.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
