wa8yxm
Oct 19, 2017Explorer III
I have done something like that with both of the light trailers (TT and PUP) I had.. Make sure you have the needed clearance around the tires. if you have dual tires or dual axles tire to tire as well.. If you do, GO FOR IT
The larger tire will be less likely to blow, will run cooler and place less strain and wear on the bearings. You may need to adjust your brake controller is all.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
