wolfe10 wrote:
Correct. Four 6 VDC "regular" golf cart batteries wired in series/parallel will give you around 440 amps @ 12 VDC.
The main issue is "what are your electrical needs"? Extended dry camping without running the generator with heavy electrical consumption OR occasional dry camping with lesser consumption?
Thanx Brett. With our current setup, we're pretty much limited to FHU camping (an oxymoron for sure). I'd like to be able to hit a state or national park that isn't FHU and be limited by holding tank capacity rather than electrics, running the genny once or twice a day. So I guess 4 days would be the max stay.
I have a Xantrex 2000 W inverter/converter in there now (can't remember the model number) and it does have settings for battery type. I also have a Magnum sitting in the basement that I can swap out if need be.
