BPRescue wrote:
jplante4 wrote:
I currently have 4 12 volt Napa "deep cycle" marine/RV batteries that I'm estimating at about 200 AH for all 4. The new arrangement should get me to around 800 AH.
There is no chance your 12V Deep Cycles are rated at 50AH each. Cranking battery; maybe, but not a Marine/Deep Cycle. You should look up the specs. Either way, DO stay with Deep Cycle
Also, 800 is way off via 4 = 12V, or 4 = 6V. With a 4 battery setup, you will be closer to 450AH regardless which direction you go.
Yeah I looked these batteries up when I bought the coach and all I got was 105 CCA, which is why I put deep cycle in quotes. They're shot anyway, I think the current solar charger is cooking them.
