jplante4's avatar
jplante4
Explorer II
Mar 06, 2017
Switching To 6 Volt
I'm planning on switching the house side of the Sahara over to 4 - 6 volts golf cart batteries this spring. Either T-105s or Interstate. I'm also planning on adding another 100 watts of solar to the 100 I already have and a new solar controller. I'm trying to get set up for some short stay dry camping.
I currently have 4 12 volt Napa "deep cycle" marine/RV battries that I'm estimating at about 200 AH for all 4. The new arrangement should get me to around 800 AH.
The Sahara has a 120 watt isolator. Will I need to beef that up as well? What else do I need to consider?
Jerry
Edit: This is something I'm planning to do myself.
  • Your math makes no sense. :h You haven't indicated which size of 12 volt batteries you currently have but even G24s would each be worth ~ 75 AH at the 20 HR rate for a total of ~ 300 AH for four of them connected in parallel. 6 volt GC-2s will each have a 20 Hr rating of ~ 220 AH so four would have a total rating of ~ 440 AH, not 800 AH.
Having RV issues? Connect with others who have been in your shoes.24,346 PostsLatest Activity: Jan 08, 2026
