MrWizard
Nov 26, 2013Moderator
that was charge mode when shore power was on
now you are on battery power, those numbers will go down
fridge should be on LP either manual or automatic
the GFIC that won't reset probably has something plugged into it that leaks power to ground, that is why it won't reset, unless its gone bad
make sure the water heater is off 'not on electric' you may have to unplug a few things to find out why the GFI will not reset
the 120v circuit breakers in the house distribution panel should be labeled
one should be connected to the xantrex inverter
the inverter will pass thru that circuit when on shore power,
and then use battery power to make 120v for that circuit ONLY, when shore power is off/disconnected
Having RV issues? Connect with others who have been in your shoes.24,371 PostsLatest Activity: Mar 21, 2026
