dddire
Nov 27, 2013Explorer
whiteysax wrote:
I did some looking around and found my converter. It is mounted right behind the fuse box. The inverter is on the opposite side connected to a chain of batteries. Am I correct to assume what I experienced during the power outage was the converter powering the 12v utilities? In that case, why wouldn't my inverter power anything? It's pretty tough to follow the wires from the inverter as they eventually run inside the undercarriage.
My fridge is residential and has no LP hookup.
I would say with 99% certainty, you're 12v utilities are powered directly by 12v.
Not sure what you're inverter is powering. Like suggested, look for additional wires from the inverter and figure out where they go.
Having RV issues? Connect with others who have been in your shoes.24,371 PostsLatest Activity: Mar 21, 2026
