whiteysax
Dec 02, 2013Explorer
Bill.Satellite wrote:
Nearly all inverters have an on/off option. Do you know if your inverter is on? Is there a wall mounted controller that allows you to set/change options?
There is a power switch on the unit as well as a knob mounted behind the unit connected by a cable which, when turned, kills the power to the inverter. It's definitely on now. The display shows the current voltage reading and says 13.1 V
There is no separate controller, however.
I set up at my new "home" tomorrow when I get to Atlanta so I'll probably take the day to settle in and start tracing as many wires as I can on Wednesday.
