Fisherman's avatar
Fisherman
Swivel TV wall mount
I have a small 19 inch LED TV I'd like to mount to the wall where it says, "Mount LED TV here". I have the muti swivel mount, the part that gets attached to the wall is vertical with 3 screw holes. Now, question of the hour, any idea how wide the mounting plate behind the wall is? I've done the old "tap tap" to hear roughly where the center is, by the sounds of it, it's only a wall stud. Of course, call the company and it's not much help. I don't have a stud finder either. I suppose I could make a couple of tiny 1/16ths holes and hope for the best. Any pointers, thanks.
  • You could use a small diameter nail to find the stud. Then the adjacent studs should be 16" distance (US home standard). Mount the TV on a board or plywood that wil span the studs.
  • philh's avatar
    philh
    Explorer III
    stud finders are cheap, or find a friend that has done construction, they will likely have one.
Having RV issues? Connect with others who have been in your shoes.24,330 PostsLatest Activity: Oct 30, 2025
