buddhawolf
Feb 22, 2020Explorer
The first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
If it still doesn't work, it may be a bad door switch or door switch mount.
One quick check is to gently hold down on the door while you press Start (or Cook).
