MitchF150
Jun 13, 2018Nomad
Most 12v electric issues are ground wire related.. If all those devices are run from the same system monitor, they might be all tied into the same ground, so that's the reason those devices aren't working?
Check the ground wire to the panel and go from there. You'll need a basic multi meter, but also need to know how to use it... You could also use a power prob, but you will also need to know how to use that as well..
Good luck!
Mitch
Good luck!
Mitch
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: Apr 10, 2025
