Stella_sunriseExplorerJun 13, 2018System monitor issue 1994 Itasca sunriseWater pump doesn’t work, idiot light levels don’t work. Checked fuse, it’s good interior lights all work so I’m assuming batteries are good to go. No power to monitor, range fan or range light. Any th...Show More
1995braveNomadJun 14, 2018Download the Winnebago wiring diagram and it will show you the wire color, plugs, and grounds which should help you troubleshoot the problem.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: Apr 10, 2025
Related ContentSeeLevel tank monitor systemTire pressure monitor systemsTire Pressure Monitoring SystemTire Monitor SystemTire Monitoring systems,
