69av is right. And from the photo there's a lot of rear overhang. you said you set tire pressures according to weight. It'd be useful to know those weights...front and rear.
What I've been thinking is you could make a test gauge. Take a couple Home Depot paint stir sticks and duct tape them to the frame so they're about an inch away from the sides of the springs but near the axle. Drive it where it misbehaves. Then see if the stix are broken torn loose or marred. If you had the stir where only the springs could reach them you have an answer.
