I have a 92 p30 chassis narrow track 30 ft motorhome.It has a little bit of an oversteer problem.I think it might be contributed to a tailwagging issue.How would i know for sure before going and payin...
Your front end may be to lite. Find the axle ratings, then divide the front axle rating by the rear axle rating. The ratio is the design weight ratio. Your actual ratio should be near the design ratio. With the weights given, your ratio is about 0.455. For example, on my coach, the design ratio is 0.52 and I've redistributed my loose load to maintain about 0.505. Question, does the ride improve with empty or little water in the black, gray, and FW and reduced fuel load? JM2¢...
