martipr wrote:
Kiwi_too wrote:
Chief,
Does AOC=Another Old Chief (or Aviation Ordinance Chief).
Do you use external power? If not, you might have a power problem, due to high cable impedance. Try running the Tailgater directly to the receiver and see if that works well.
Aviation Ordnance. As my post stated, it works fine when running the tailgater directly to the receiver. The question is how to do that without and open window or door.
Chief,
I am retired Army. I have worked joint and knew your rating. I was just poking at ya.
It sounds like you are not running external power to the Tailgater. I would recommend a separate RG6 install for the Sat to receiver.
