MEXICOWANDERER's avatar
Apr 05, 2017
Take A Moment For A Chuckle...
This is not a factory alternator. It is a "redesigned" aftermarket Ford Alternator. Below the dotted line is a cut and paste of the original ad. Read the entire ad. Every Word. Now before you peek, lookie look at the STEEL battery output stud. Now do I look like I got the word Stooopid written ALL OVER my face? 320 amps output. Enjoy while I smirk...
______________________________________________________________________
100% NEW REPLACEMENT ALTERNATOR
HIGH OUTPUT 320AMP FOR
FORD F-SERIES PICKUPS
Specs
• 320 Amp/12 Volt, CW, 8-Groove Pulley
• Denso IR/IF
• FAN TYPE: IF
REGULATOR TYPE: IR\
• VOLTAGE:12
• AMPERAGE:320
• ROTATION CW
• PULLEY CLASS:8 GROOVE
This alternator comes with an overdrive pulley worth $30 require 1" smaller belt if squealing or belt slipping noise.
Do not remove or use or original pulley which may cause drop in voltage on idle or under 1000RPM.
