MEXICOWANDERER's avatar
Apr 05, 2017
Take A Moment For A Chuckle...
This is not a factory alternator. It is a "redesigned" aftermarket Ford Alternator. Below the dotted line is a cut and paste of the original ad. Read the entire ad. Every Word. Now before you peek, lookie look at the STEEL battery output stud. Now do I look like I got the word Stooopid written ALL OVER my face? 320 amps output. Enjoy while I smirk...
______________________________________________________________________
100% NEW REPLACEMENT ALTERNATOR
HIGH OUTPUT 320AMP FOR
FORD F-SERIES PICKUPS
Specs
• 320 Amp/12 Volt, CW, 8-Groove Pulley
• Denso IR/IF
• FAN TYPE: IF
REGULATOR TYPE: IR\
• VOLTAGE:12
• AMPERAGE:320
• ROTATION CW
• PULLEY CLASS:8 GROOVE
This alternator comes with an overdrive pulley worth $30 require 1" smaller belt if squealing or belt slipping noise.
Do not remove or use or original pulley which may cause drop in voltage on idle or under 1000RPM.
  • Looks copper to me too, but I didn't check it with a magnet so who knows.
  • i guess the stud is steel
    but it sure looks copper color in that picture
    although it 'looks' to small for 320 amps, but there is nothing else in the picture to judge size of stud or anything else
Having RV issues? Connect with others who have been in your shoes.24,303 PostsLatest Activity: Aug 21, 2025
