MrWizard
Jul 29, 2018Moderator
1Longbow wrote:
I don't know much about them .old one was 1750 amp? Just thinking, that needing to replace it ,should I just go bigger. The old one did everything I need i guess.
that would be 1750-watts
if it has quit working, either inverting or charging
and you want to replace it ?
then 2000w Pure Sine Wave aka PSW
will do everything the 1750 did and have a little more power
IF for some reason the old just seems like it is still working but not as good as it used too
think about getting your batteries and the wiring connections
checked out, ... before spending money on a new inverter
it might be old worn batteries ?
new batteries could cost you more than a new inverter
be sure what you need before you spend the money on a new inverter
then find out you still have a problem and need new batteries
