ridemtra's avatar
ridemtra
tandem axle equalizer
anyone have an equalizer flipped over with the rear leaf spring below equalizer have both sides in the same position can this be returned to original position without total disassembly
  • ridemtra wrote:
    what was your procedure thinking of lifting to relax suspension and jacking under equalizer link?
    Yes that is it. Push link back into position as you put weight back on the spring.
    They will flip back into correct position. We had one do this last year while traveling on Indiana interstates. The guys at Equalizer noticed it & pointed out next bump in the road should snap it back. Sure nough by Tx it was healed
  • Ivylog's avatar
    Ivylog
    Explorer III
    Jack on axle or end of equalizer bar that is correct and using a bar you can snap the wrong one back in place...it may go back on it's own.
  • what was your procedure thinking of lifting to relax suspension and jacking under equalizer link?
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 15, 2026
