SteveAE
Nov 06, 2013Explorer
Good comments, thank you.
Skip: Even though I have one, I don't use a generator, hence no 120 VAC...that I want to run a resistance heater with anyway.
SMK: Actually, it is during the night that I want the system running. Day time temps in the upper teens and low 20's really aren't an issue for me. It's those overnight lows that I fret about. My thought was to transfer the entire contents of the water heater into the tank as quickly as the plumbing will allow, once a hour (or so). So while the water pump will run for long enough to pump 5 gallons, it shouldn't take too long to do this. Otherwise the pump will be off. I have worked hard over the past couple years to quite the pump so there isn't much noise and the power consumption (2.3 Amps) is much less than that dang forced air furnace.
MLTS: From the transfer point into the tank will be all downhill, so the line (tank vent tube) will dry out sufficiently so no nasty green stuff can grow (it's very dry here most of the year).
Steve
Steve
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jun 25, 2026
