JiminDenver
Nov 07, 2013Explorer II
Now you are a step away from using the system for additional heat. Add a few Ts and a by pass valve to the hot side in the bath and you can run the hot water through a small baseboard heater, do it again after the kitchen sink and pump and you will get some benefit other than keeping your pipes from freezing.
Having RV issues? Connect with others who have been in your shoes.24,396 PostsLatest Activity: Jun 24, 2026
