DrewE
Mar 07, 2020Explorer II
I agree, the fuse would be the first thing to check.
A bad switch is certainly a possibility. Sometimes you can tell by feel if a switch is wearing out, sometimes not so much. A loose or broken wire or solder joint in the monitor panel circuitry could likewise be another possible cause.
Having RV issues? Connect with others who have been in your shoes.24,209 PostsLatest Activity: Feb 24, 2025
