- wa8yxmExplorer III
honda1 wrote:
are tank pads 12v or 120v , just wondering if going down road will heat off 12v batteries . tks ..
The answer is YES
Meaning you can get them either way. 12 volt sucks a LOT of battery power though, odds are you won't be happy with them. Tom/Barb wrote:
So did the buyer or Newmar choose 120vac over 12vdc?
I've known our coach from day 1, I helped the first owners buy it and pick it up. I know what has been done to it after that. So I do know that the tanks have never been worked on or anything added.
the heat pads were placed in the coach as built.
Any thoughts on why that power was chosen?
Any issues?- Tom_BarbExplorer II
dougrainer wrote:
Tom/Barb wrote:
dougrainer wrote:
Tom/Barb wrote:
dougrainer wrote:
Tom/Barb wrote:
our's are 120 volt. they will not work without shore power or the gen-set running.
IF you still have the Newmar. Newmar back then used the Furnace as a heat vehicle for the Water Bay/Tank compartment. They used a extra 12 volt fan connected to the furnace duct to blow hot air to the Water bay. I have never seen a Newmar(motorized and not a King or London Aire)(1993 to 2009) use any Heated Pads for the water tank system. Are you positive they were not added after market? If you think you have them, where is the wall switch to activate those heaters? Doug
This is true, normally the basement heater will take care of the tanks. but when you don't run the furness, you plug in and turn on the pads.
and no, they are not an after market, they came as an option when the coach was bought.
Yes we have a wall switch in the bathroom to turn them on or off. it has a red glow light when they are on. I check them now and then.
I've never used them, we are normally not on the road in extreme cold weather, and when it is really cold we are home and the tanks are empty and pink added, and the water system is blown out.
I find that odd. I double checked the standards and options for your year model and it did not list ANY optional tank heaters. Doug
Our coach was a custom build for the first owners, They could have asked for the heaters to be part of the build.
I understand that. BUT, you have fallen for one of the BIGGEST mistakes RV owners make. YOU did NOT buy the unit new. So, when you post items about your RV, you should NEVER assume that what YOU have was standard or came with the unit new. I, on the other hand, serviced(we sold) Newmar from 1993 until 2008, and we sold a boat load of MADP especially from 1999 until about 2005. So, when you posted that, I was very surprised as I KNEW Newmar did not install 120 or 12 volt heat Pads on MADP back then. That is why I looked up the original Standards/Options Sheet for your Year. Now, Back them , Newmar would option off the sheet items for order if it fell within installation parameters. But, It IS possible that your 120 system was added by the selling dealer as Newmar would not have added it. Off the sheet options by Newmar back then would NOT include parts that Newmar did NOT have in stock for installation on the production line. Doug
I understand that. BUT, you have fallen for one of the BIGGEST mistakes RV owners make. YOU did NOT buy the unit new. So, when you post items about your RV, you should NEVER assume that what YOU have was standard or came with the unit new. I, on the other hand, serviced(we sold) Newmar from 1993 until 2008, and we sold a boat load of MADP especially from 1999 until about 2005. So, when you posted that, I was very surprised as I KNEW Newmar did not install 120 or 12 volt heat Pads on MADP back then. That is why I looked up the original Standards/Options Sheet for your Year. Now, Back them , Newmar would option off the sheet items for order if it fell within installation parameters. But, It IS possible that your 120 system was added by the selling dealer as Newmar would not have added it. Off the sheet options by Newmar back then would NOT include parts that Newmar did NOT have in stock for installation on the production line. Doug- Tom_BarbExplorer II
Our coach was a custom build for the first owners, They could have asked for the heaters to be part of the build. Tom/Barb wrote:
I find that odd. I double checked the standards and options for your year model and it did not list ANY optional tank heaters. Doug- TurnThePageExplorer
time2roll wrote:
I on the other hand did the 12v/120v combo on my fresh water and just 12v on the holding tanks, I also added a 12v on the grey water drain right near the valve.
I went with 120v pads for the waste tanks and 12v/120v combo for the fresh water. You will be plugged in or running a generator near continuous in these conditions.
12v tank heaters range from 4 to 12 amps depending on tank size. I was looking at close to 50 amp load on my 55 amp converter. Seemed like a bit much and we all know a converter can quit. While the pads would cycle on the thermostat in mild conditions the potential seemed a bit much.
I did get the 12/120 combo for the fresh water to prevent freeze up during transit. The empty or half full waste tanks I was not as concerned about if they started to freeze. I did find once the 120v was not enough for the fresh water to keep water flowing and needed both elements heating. My tanks are exposed.
http://www.annodindustries.com/shop/shop/heaters-and-warmers/rv-and-marine/rv-tank-heaters.html - Tom_BarbExplorer II
I've never used them, we are normally not on the road in extreme cold weather, and when it is really cold we are home and the tanks are empty and pink added, and the water system is blown out. Tom/Barb wrote:
IF you still have the Newmar. Newmar back then used the Furnace as a heat vehicle for the Water Bay/Tank compartment. They used a extra 12 volt fan connected to the furnace duct to blow hot air to the Water bay. I have never seen a Newmar(motorized and not a King or London Aire)(1993 to 2009) use any Heated Pads for the water tank system. Are you positive they were not added after market? If you think you have them, where is the wall switch to activate those heaters? Doug- I went with 120v pads for the waste tanks and 12v/120v combo for the fresh water. You will be plugged in or running a generator near continuous in these conditions.
12v tank heaters range from 4 to 12 amps depending on tank size. I was looking at close to 50 amp load on my 55 amp converter. Seemed like a bit much and we all know a converter can quit. While the pads would cycle on the thermostat in mild conditions the potential seemed a bit much. Not going to get that 12v power from my truck into the trailer anyway. Would be a significant 12v load on a MH alternator.
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 12, 2026
