fairlaniac's avatar
fairlaniac
Tankless heater in seasonal TT
We have a TT in a park near the beach in Delaware. I have the OEM propane hot water heater on board that we use in the off season. Water is off from 10/15 - 4/15 annually. IO have a 275 gallon IBC tank with fresh water to use in the off season. During season I have an electric hot water heater and I valve off the onboard water heater during spring/summer. The onboard heater developed a rust hole leak. I'm thinking about a tankless heater but I'm trying to figure out if my two heater system will cause issue? In the off season I use the 12V pump for my water and in spring/summer I use park water pressure. Would a tankless have issues with the different ways of getting water to the heater?
FYI - I don't use the electric heater in the off season because each time we leave off season I winterize and I would need to dump the 30 gallons in the electric heater each time. So we use the 6 gallon and do a typical winterize each time. 275 gallons lasts us 3-4 off season trips.
thanks,
Doug
  • Thank you for the replies. Good info to know. I think we'll just make it easy and get a new propane R water heater.
  • DrewE's avatar
    DrewE
    Explorer III
    valhalla360 wrote:
    - Now if you have a 50amp/240v supply, you can get a high wattage unit that can do the job (check the rating for temperature increase relative to flow)
    An 8 kW model (which is about the maximum you could reasonably hook to a 50A circuit and have some power left over for other things) would provide well less than 1 gpm with cool incoming water, and almost certainly be unsatisfactory for a shower. 15-20 kW might be a reasonable size, which requires at least a 100A service.
  • Shouldn't have issues with the source of water pressure.
    The bigger question is what is the source of power for the water heater?
    - We had a propane one on our boat and I hated it because you had to fiddle with it a lot to get the temp right then if you adjusted the flow at all you either got an ice bath or scalded.
    - Electric ones need a lot of juice particularly if we are talking about the winter when the incoming water may only be in the mid 30F range. If you only have a 30amp power supply, you likely can't bring the temp up enough to have a reasonably warm shower.
  • Since you are working off a finite supply in the winter months I would stay with the rv type unit. less temptation to stretch out the showers and use your water faster.
Having RV issues? Connect with others who have been in your shoes.24,352 PostsLatest Activity: Jan 21, 2026
