time2roll
5 years agoNomad
I thought most of these inverter/fridge installs had a transfer switch to power the fridge direct when 120vac is available. Post the inverter model number so we know.
If the setup has just 2 batteries and you plan to do a lot of off-grid camping you may find 4 batteries it a bit easier to maintain charge.
As for actual battery charging it would be best to post the converter or charging system model number to give realistic charging expectations. Of course if you are running the A/C from the generator 12+ hours a day the converter may not matter much.
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: 50 minutes ago
