JoeH
Aug 26, 2020Explorer III
I suggest you install heat shield/sound dampener material regardless if it is "needed". If boondocking, you'll appreciate the reduction in heat/noise while running the genset. Dynamat is one supplier of material and/or you can look at marine quality engine room insulation materials.
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 15, 2026
