HiTech's avatar
HiTech
Technical adjustments or selections for hot weather camping?
Do you make any different selections of technology for hot weather camping?
For example some solar panels do much better than others as their temp goes higher. Some mounting systems allow much better airflow. Some batteries are designed for high underhood temps. Maybe some other electronics are better in the heat such as solar controllers, inverters, gensets...etc?
Do you make any special provisions for additional fans? Fridge? Extra fans venting the converter? Extra cooling for the inverter? More genset cooling?
Do you specially shade any part of the RV to avoid direct sun raising the operating temp of any system?
I know you see much smaller RV's with 2 AC's on the roof here than I was used to. I have also seen a large number of home made RV's with NO windows at all, and many with covers over or behind the glass that look like they stay on all summer, if not all year.
Do you do anything special with the tires? They seem to die earlier with extreme road temps.
Jim
  • Hi Jim,
    I've just ordered window covers, both interior and exterior. I do have a thermostatically controlled pair of fans for the fridge.
    I do keep my vents open in summer time and try to open a window on the shady side of the rv.
    If I can I'll park with the nose facing north.
    I do run my fantastic fan on low.
    9 a.m. and I'm getting 9 amps @ 13.5 volts. That's enough to run parastic loads, the fridge fans, and the fantastic fan.
