C Schomer wrote:
I need to buy a new brake controller if I can't fix my old Jordan and I have some questions that I can't find anywhere in my searches .  I know there's assessories for the PIII but is there only one part number for the controller itself ?  Does the PIII come with a wiring pigtail that can be mated to the vehicle  brake controller pigtail or is it necessary to buy the vehicle specific wiring harness  for the PIII ?  I have one trailer with electric magnet brakes and another trailer with electric hydraulic brakes .  Does the PIII work well with both ?  Is there any other good brake controller for both kinds of trailer brakes ? Thanks ,Craig
You can fix the common problems with  Jordan 2020 which is the leaf switch contacts inside (main one is intermittent work/not work) .
If you do a search with Jordan and the symptoms you should come across some great info on how to fix them.
As a Jordan owner myself, I highly doubt you will find a lower cost controller that will works as smooth and well as a Jordan 2020..
My newer trucks have IBC and I can tell you those are about the only controllers that work as well as a Jordan 2020.
If you really need a new controller, there is one that plugs into your OBD2 diagnostics port.. Can't think of the name right now but from my understanding it reads the vehicles data and uses that to determine braking.. Not cheap as a Jordan was but worth a shot.
On edit..
Just remembered the controller name..
DIRECLINK!
You can find more info
HERE
