tom496's avatar
tom496
Weak Braking w/ Tekonsha P3
I have been using my Tekonsha P3 brake controller for about five years with two different trailers without problems until this spring when I noticed weak braking. Braking was fine last fall, so the condition seems to have developed over the winter. The trailer brakes offer little or no braking help when activated only with the brake pedal. They slightly but noticeably slow the vehicle when I manually push the lever on the controller all the way to the left without depressing the brake pedal. The TV is an '05 Suburban with tow package. I replaced the 7-pin connector on the trailer side, which was in horrible condition, but to no avail. The boost mode is set on B2.
These are the readings I'm getting from the P3's diagnostic mode in my driveway with the trailer connected and engine running:
BATTERY VOLTAGE
14.3 V (12.25 V with engine off)
STOPLIGHT
12.0 V
OUTPUT VOLTAGE
No braking -- 0 V
Brake pedal fully depressed -- 3.2 V
Manual lever pushed fully to the left -- 12.1 V
OUTPUT CURRENT
No braking -- 0 A
Brake pedal fully depressed -- 1.5 A
Manual lever pushed fully to the left -- 10.0 A
I'll be grateful for any thoughts or suggestions on next steps. I have a multimeter. Thanks.
