pianotuna's avatar
pianotuna
Nomad III
Sep 16, 2015
telecom batteries and boondocking
Hi all,
First night boondocking on the new batteries.
I ran a computer for 5 hours (100 watts) via my large inverter, and a 7 amp 12 volt heating blanket for 7 hours.
Battery voltage started at 13.1 but quickly settled down to 12.8
The usual parasitic loads were active.
In the morning batteries were at 12.5 volts.
I turned off the inverter, then drove for about 1 hour at city speeds. Initial charging was at 40 amps. By the end of the drive 7.4 amps were coming from the alternator and 2.5 from solar. End of drive placing my foot on the brake at stop lights caused current to flow from the house jars to the engine. (about 1.5 amps). With transmission in neutral that went back to the 7.4.
At my destination, after turning off the engine, and turning off the solar voltage was displayed as 13.1. I used the fridge on 120 volts ac (30 amp load) for 1 minute to "knock down" surface charge. Battery voltage displayed at 12.9.
It is a grey day. Blue Sky 3024di controller is sending 2.2 amps to the battery bank at 13.1 volts. Normal parastic loads are running.
Ambient temperature is 11.3 C (52.3 f)
