pianotuna
Sep 16, 2015Nomad III
8:15 and laptop needs charging. Loads the same as before. Generator run time will be 30 minutes.
Resting voltage 12.9 (with a load of 1.6 amps)
Magnum charging at 14.4 volts 50 amps. After 15 minutes that dropped back to 20 amps, then moved up to 30. End at 25 amps.
Voltage 13.5.
Ambient temperature 8.9 c
Voltage 13.5.
