Lwiddis
Aug 04, 2020Navigator
“Inverters drain power just being on, and TV will draw more power if going through an inverter than if just a 12v tv. It may not matter most of the time, but when your batteries are getting low then it matters a lot.“
Who leaves a small inverter on when not in use? More power used? Not that much with 90%+ efficiency. BTW the TV (by itself) draws the same amount of power on an inverter or plugged in.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 23, 2026
