wa8yxm
Aug 04, 2020Explorer III
First that 12 volt outlet likely is not very robust ( cab not handle big loads)
2nd Likely NOT a problem with modern power sippers.
Second. there was. a while back a lot of yammer about 12 volt TV's being damaged by the 13.6 volts of the standard RV system... How true it is .. I DO NOT KNOW
Next.... Samsung makes a 14 volt job... (Solved the yammer)
FInally..
Many today use power bricks to convert 120vac to ___ (12 or 14 or even 19)
These are .. at best 90% effie=nt
Likewise the inverter that makes 120 out of 12. at best 90% efficiebt
So if you boondock a lot the 12 volt model makes a lot of sense
FInally..
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 23, 2026
