RoyB
Mar 14, 2014Explorer II
All I ever use my 2KW Honda generator BAT CHARGE cable for is to operate a 12VDC LAMP.
It is worthless to me as a BATTERY CHARGER.
It is just as easy to connect my trailer Shore Power Cable to the HONDA EU20001 2KW Generator Set using a RV30A-15A 120VAC "DOG BONE" long adapter from WALMART. The generator then will operate the trailer on-board converter/charger and properly re-charge my batteries in a short three hour generator run time using smart mode charging technology.
The unregulated 8A DC source is more or less worthless for me to use to re-charge any of my batteries... Anything less than 14.4VDC with a capacity of around 20AMP DC CURRENT per battery will take many many hours to re-charge a 12VDC Deep Cycle Battery.
This is what Progressive Dynamics says about re-charging DEEP CYCLE Batteries
"Progressive Dynamics ran this test on the amount of time it took a PD9155 (55-amp) converter/charger set to three different output voltages to recharge a 125 AH (Amp Hour) battery after it was fully discharged to 10.5-volts.
14.4-VOLTS (Boost Mode) – Returned the battery to 90% of full charge in approximately 3-hours. The battery reached full charge in approximately 11 hours.
13.6-VOLTS (Normal Mode) – Required 40-hours to return the battery to 90% of full charge and 78-hours to reach full charge.
13.2-VOLTS (Storage Mode) – Required 60-hours to return the battery to 90% of full charge and 100-hours to reach full charge."
Your 2KW Generator will not run that long on a tank of gasoline except in the 14.4VDC BOOST MODE...
A built-in SMART MODE BATTERY CHARGER circuit like the B&D VEC1093DBD 40AMP portable charger incorporates would be a great feature for the 2KW Honda Generator. This is one of the items I plug into my 2KW Honda Generator to re-charge my deep cycle batteries when not around my OFF-ROAD POPUP trailer.
I would say most campers that use their trailers off the power grid will have a minimum of two deep cycle batteries being used that would need to be re-charged each day using your Honda 2KW Generator.
Just my thoughts
Roy Ken.
Just my thoughts
Roy Ken.
Having RV issues? Connect with others who have been in your shoes.24,362 PostsLatest Activity: Mar 02, 2026
