BobnSofi's avatar
BobnSofi
Temp Tire Bridge over Drainage Ditch ??
Hi All,
We want to install and remove it after use.
Want to temp bridge a street front drainage ditch. Our relatives are able to get their small Class C through it and onto their property. We have a very large single axle Class A pusher, and are not in the mood to try this without some sort of temp bridge engineering. Seems you could arrange concrete retaining wall blocks in there for tire pathways, but they weigh 50lbs each. The area has hard clay soil, so sinking is not an issue.
We want to EASILY install and remove it after use.
How do yo pros suggest we handle this "temp bridge" over an earthen drainage ditch?
!!! Thanks in advance !!!
  • Bundles of bamboo tied together and in depression under wheels. Inexpensive, light, and disposable.
  • How much weight on that Class A FRONT axle and REAR axle......
    Whatever you use will have to support that weight without being pushed down into the ditch.
    Several 4X4's stacked next to and on top of each other??
    Steel plate........great if you have a fork lift or font end loader to move it.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Mar 27, 2025
