Sam_Spade
Jul 15, 2016Explorer
WDE wrote:
I camp with the coach battery disconnected (not charging) and running the 12 volt system off the converter.
There is absolutely, positively NO reason to do that; none, nada.
In fact, it probably means that your batteries are partially discharged most of the time and it's hard on them too.
Not having a fairly constant load on the converter/charger might have been hard on it too. It wasn't intended to work that way.
And yes I know you've been doing that for a thousand years; still doesn't make it right.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
