Sam_Spade
Jul 21, 2016Explorer
red31 wrote:
Following sam's advise and this is what happensWDE wrote:
I have had to replace two batteries after a short period due to overcharging by the converter (and yes, I kept the electrolyte level correct).
And it appears that some people can't read OR understand. SIGH.
THAT is what happened when he was using the old, cheap, probably failed original single stage converter.
His first attempt at a logical solution (failed) was to keep the battery disconnected.
His second attempt, replacing the converter with a good one (the proper solution) unfortunately didn't also include "backing out" the first failed attempt.
Now are things clear ?? Somehow I doubt it.
Having RV issues? Connect with others who have been in your shoes.24,362 PostsLatest Activity: Mar 02, 2026
