mph_medic's avatar
mph_medic
Terk Trinity Xtend Amplified HDTV Antenna with Wifi Extender
Terk Trinity Xtend Amplified Indoor HDTV Antenna with Wifi Extender
Looking to see if anyone has installed this unit and how it is working for them in their RV.
  • Well.. sitting in the forward overhead, it might help
    Sometimes, this stuff will surprise , and turn out better than expected
  • I took the batwing off put a JACK up but the Y power thingy broke I have a replacement on the way.. until then I saw this and thought if it will pick up HDTV and extend CG wifi win/win... I have a spot up front in the over head area to put it and thought the fiberglass cap should not hinder the signal.. but wanted to see if anyone else had used this in a RV setting... tks..
  • I had never heard of it before
    so i looked it up
    frankly i have my doubts to the validity of the claims
    and its ability
    do you want to try this at the stick and brick or in the RV
    i really have my doubts, sitting on the TV table in an RV
    either for TV or trying to extend CG wifi
    if that thing can get a useable wifi from CG while sitting on a table then your PC or tablet should work with the CG wifi
    extending the router signal from one end of your stick house to the other
    is different, and it 'might' do that, but so would a $20 travel router that plugs into a wall outlet
  • I had a Terk ? ISTR 55 ? outdoor antenna for four years as a replacement for a busted batwing because the Terk was on sale. The Terk worked great with OTA digital, no complaints. It also worked with the RV's "12v" no problem using the original Winegard panel. Didn't have to use its own Terk wall wart and an inverter.
    It went downhill after the third year because water got into the antenna somehow (as learned during the autopsy) where it is sealed at each end cap connection and it rusted out inside.
    I now have a Jack, which also works well, but I expect it will last longer than the Terk did.
